Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
PS4 Model CUH-1216B only has 2 screws, how do I open it
Hello, my PS4 Model CUH-1216B only has 2 screws on the back. Can you please explain how to open it. Since a few days it won’t start up again. Starting it, I only get a screen saying “connect the dualshock 4 with a USB-cable and next press the PS-key”, which doesn’t do anything. I got it once in safe mode and tried to reinstall everything, but then it crashed again and now I am stuck! Does anyone has an idea about what could be causing this? Thanks for your support.
Bob
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If you have already exhausted all the options in safe mode with the full PS4 initialization firmware file downloaded into the USB then it’s going to be a bad hard drive.
Software update can fail with error code if the blu-ray drive is not working. As long as you can eject and insert discs into the PS4 the blu-ray drive should still be good.
PlayStation 4 Hard Drive Replacement
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
Imagem de PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
Produto
$29.99
Esta resposta foi útil?
Pontuação 1
Press and hold the power button until you hear two beeps: one when you first press and another seven seconds later.
Pontuação 0
1 comentário:
i can't click on the other options except for number 7 , what should i do ?
por
Adicionar a sua resposta
Bisshop Jyr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 1,451
