Ir para o conteúdo principal
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
54 Perguntas Visualizar todos
Why battery is 100% but display show me 0%?
Hello,
I don't know why but suddenly my qicycle stops to work… The battery is charged but the display show me 0%.
I tried some solutions like disconnect and reconnect torque cable and try to update by official and unofficial app the firmware but It doesn’t work.
When I try to upgrade the firmware, the process failed every time and I tryed few times.
I don't know really how to solve the problem, please help me!
thank you very much!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
I have the same problem. Did you find the solution?
Esta resposta foi útil?
Pontuação 0
3 comentários:
I found it. In my case it is a broken cable into the ankle brake point of the cycle. I replaced it and it works just fine. Open the ankle and check the cables.
por
Can you help me? I have the same problem
por
Can pin point where is the ankle brake point of the cycle? Thank you.
por
Adicionar a sua resposta
agrotheclown será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 584
