Ir para o conteúdo principal
The Nerf Maverick is one of the most popular guns in the company's lineup and is beloved for its simplicity and ease of use.
when I pull the triger my gun makes a loud bang and dose not fire
when i pull the triger my gun makes a loud bang and dose not fire how do I fix my maverick?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It seems like your O ring might have broken.
The plunger is retracted into place when you $!^& the blaster, and then when you pull the trigger it is released and the spring sends it forward to deliver a blast of air to propel the dart.
If your O ring is bad, than you no longer have the sealing effect on the plunger and it wont be slowed by air pressure being forced out through the cylinder and barrel.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
johnsonharry22 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 256
