Ir para o conteúdo principal
The 5th generation of the Moto E smartphones, released in May 2018. Model number XT1944 and XT1920DL
16 Perguntas Visualizar todos
My phone is showing a warning code I've never seen before..
Can anyone tell me what this is? My phone popped this warning code up out of nowhere and I have never seen it before on any of the phones I've ever owned. Is my phone being hacked?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @rachellparamo96
Try the following in case there is a virus or malware installed in the phone
Download and install an anti virus app- example only
Download and install an anti malware app -example only
When you have installed both the apps, re-start the phone in ''safe mode'' and then locate the AV app in the apps list and run it. Follow the prompts if it finds any viruses.
Once the AV app has finished, find and run the anti malware app and do the same. Hopefully between the both of them they will clear your system back to good health.
Have you installed any new apps lately?
Esta resposta foi útil?
Pontuação 2
2 comentários:
I've just gotten the phone last month off someone so yes I have and I already had malware bytes on my phone because something felt fishy about my phone so my adopted dad has been using that antivirus software for as long as I can remember. But it hasn't found anything and I've got it on system auto scan daily. But oh and I've got the other one downloaded that you listed as an example and my phone is still in safe mode. The antivirus apps are greyed out along with most apps during this time in safe mode so should I turn safe mode off? If so how do I do that? I've got a Motorola Moto e5 cruise
por
Hi @rachellparamo96 ,
To get out of safe mode it should be just a matter of turning off the phone in the normal manner and then starting it again in the normal manner.
Do you still get the warning in safe mode?
If not then a downloaded app is the cause of the problem. The trick is to find out which one. You'll need to uninstall each downloaded app (start with newest first) one by one and then test the phone in normal mode between each uninstall. When it works OK with no warnings the last downloaded app that was uninstalled was the culprit.
Are you online when the warning occurs?
A quick search online regarding "One Signal" or One Signal Rest"( which is shown in the warning) seems to indicate that something is trying to establish contact with a server and has failed.
por
Adicionar a sua resposta
Rachel Cox será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 309
