Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Is it ok to replace the screen
I dropped my phone and now it has a slight bend. Should I get it fixed?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Why not sure you can fix it .There is small bend no problem.
por
Adicionar um comentário
1 resposta
Solução escolhida
Since the iPhone logic board inside is firmed to the housing with screws, there might be consistent pressure on it that could lead to troubles sooner or later. Screen too may be working bad and create issues. It would be a good idea before replacing screen to straighten the housing or replace that part too after removing the logic board.
Here’s the guide to help you do the job:
iPhone SE Logic Board Replacement
Esta resposta foi útil?
Pontuação 4
3 comentários:
The bend is only on the volume rocker side And the replacement is Coming in a week. Is it ok to wait or should I fix it as soon a possible?
por
@shaven_gren It shouldn't be a problem, the left half of the housing is mainly occupied by the battery and smaller components. Unless you feel unusual constant heating coming from the phone it won't be a problem to use it as it is for some time.
por
Alright thanks
por
Adicionar a sua resposta
rossianthony004 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 122
