Ir para o conteúdo principal
O Wii U é um console de videogame emparelhado com um dispositivo portátil fabricado pela Nintendo, que permite aos membros jogarem no GamePad. O reparo do console é simples, já que o dispositivo é bastante modular.
Wii U Not starting; Blinking red light
i was recently wanting to play on my Wii u for the first time in a month or so. the light tuns on blue for a second with the fan coming on then blinking red light. it has been opened recently to be cleaned. any ideas
Esta é uma boa pergunta?
Pontuação 1
1 comentário
J'ai ma Wii U qui affiche un voyant rouge tout en clignotant quand je tante de l'allumer, et le ventilateur à l'arrière de la console ne tourne pas. Que dois je faire?
I have my Wii U flashing a red light while flashing when I try to turn it on, and the fan on the back of the console is not spinning. What should I do?
por
Adicionar um comentário
4 respostas
Pergunta mais útil
I know this is an old post, but if you opened up the console and removed the disc drive, be sure to plug the flex cable in the same way it was removed. You can swap the cable around and it will fit, however you'll get the blinking red light when you try and turn it on.
Esta resposta foi útil?
Pontuação 4
3 comentários:
thank you!!! :)))
por
Worked wonders, always try this!
por
Yo estoy en la misma situación pero yo la desarme porque no me quería agarrar la sd pero cuando la desarme me pasó lo mismo pero ya le hice de todo y no encuentro la falla
por
Make sure plugs are all plugged in. Did u have a game in it? Try to get it out and try again. Or maybe you left it on last time you played which can overheat it
Pontuação 0
https://www.bing.com/search?q=How%20to%2...
Pontuação 0
Nothing is helping my Wii U it is always just a blinking red light I don’t know what to do anymore I try cleaning it and cooling it down I left it unplugged for over a month came back and still just a blinking red light.
Pontuação 0
Adicionar a sua resposta
jake será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 44
Ao todo: 3,171
