Ir para o conteúdo principal
Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a four-door sedan.
12 Perguntas Visualizar todos
Oil leaking on spark plug boots
I have oil leaking on my spark plug boots and its starts but it struggles driving. I changed the spark plug and put a head gasket seal on the car. I have some bolts missing from the head gasket and I'm having some real difficulty getting the oil from where the spark plugs are, Any suggestions? Will replacing the bolts and getting the oil out where the spark plugs is help my car run like it used to? Please help or point me in the right direction!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Just a little clarification…
1) where is the oil leaking from?
If it is leaking up from the spark-plug boots you would need to replace the valve-cover gasket, make sure you replace the 4seals for the spark-plug wells not just the outer perimeter seal.
2) Did you replace a head-gasket or a valve-cover gasket… if you replaced a head-gasket and are missing cylinder head bolts, you could have compression problems… the cylinder head must be properly installed and torqued to spec before attempting to run the motor.
If you meant the valve-cover gasket, then it is less serious, but missing valve-cover bolts can easily cause uneven seal pressure leading to more oil leaking… I would recommend getting any missing bolts installed to make this easier to diagnose.
3) for oil in the spark-plug wells use paper towels to soak up the oil (depending on the amount of oil in the wells this could take repeated attempts before the towels stop coming up covered in oil)
This will be easiest if you clean the wells while the valve-cover is off... (and safest for the motor if you do this while the spark-plugs are still installed, just fold the towels up and slide them down around the spark-plugs, you really don't want grime falling into the combustion chamber) but as long as your seals are no longer leaking, this shouldn't take too long… use a flashlight to inspect for oil seeping back in after you get it wiped up.
Post back with pictures if you can…
Esta resposta foi útil?
Pontuação 1
I had this issue and from what I understand from my own research on these cars is that’s a common problem, replace the valve cover gasket and grommets. Sometimes the boots need to be re-seated but not always but I was able to just replace the valve cover gasket and my issue stopped.
Pontuação 0
Adicionar a sua resposta
Tamara será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 976
