Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
Ghost touch issues after screen replacement
Cracked my screen, went and got it fixed at a local phone repair shop. Having issues when for example scrolling down facebook, or any up and down swipe motions. Really unresponsive and kinda jumps around when it does register the touch. Is this the fault of the repair shop? And should they take it back and fix it? Thanks
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Thanks for your speedy response. Hopefully they don’t try to pull anything and sort it out for free
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Definitely it is an after-repair issue. Sometimes when technicians use wrong glue to mount new screen (it get’s hard as stone instead act like rubber). In your case the screen gets too much tension on glass and it gives you self-clicks.
Another repair required. Probably they will glue it off and again with better glue or more precise cleaning.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
rory será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 2,185
