Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
Water damage iPhone 3GS
The other day I had the bright idea to go to the pool with my iphone in my bathing suits pocket. I wanted to listen to music but I found a way to forget my headphones. Anyways, so yeah I have my iphone in my pocket and once at the pool decided to jump in the water so I would find the water less cold. Thats when I realised what i just did and told myself: "please don't tell me you just did that". So yeah i don't even want to look at the phone thinking after once dropping it from a 2nd floor face on the ground (no damage) and once dropping it in the water with no damage, this time that was it. So I stay a bit at the pool feeling stupid and letting my phone dry to the sun. After 15 minutes, I decided to go back home and search "bring my iphone back from the dead". I find the rice trick do that for 3 days. Then open my phone put alcohol to kill any corrosion and stuff. Plug my iphone and too good to be true It opens no problem, i unplug it no battery problem, i start texting my friends its working and then when i want to go back realise... no more home button. First reaction ill open it again to see If i missed a spot and try turning it off... no more power button. So yeah i have my iphone back perfectly working, no lcd or battery problem and no data loss, but for my power button and home button... Has this happened to any of you? What should i do? I don't want to order a bunch of buttons to realise its not the button or whatever. Is there a way to diagnose where the problem is from? logicboard? button itself? Looking at the logicboard there doesnt seem to be corrosion or anything.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
sounds like you did a good start on the first aid. I'd let the phone"die" or run out of charge, then open it up and use the alcohol to clean the top of the dock connector (it makes contact with the home button) and then I'd clean all of the connectors on the motherboard and all the flex ends. allow it to dry and repeat the process. when it's dry again i'd reassemble and see what results you get. If still no home button, take a look at the gold prongs on the back of the home button and check you haven't flattened them taking the display off..lift them up a little. if still no joy on the power button is part of the headphone jack/volume/mute flex.. the guide is on the right. I'd look for a part that has the metal connectors already attached, not just the flex on it's own-it'll make life easier and there is usually not a lot of difference in price. the home button could be the dock connector or the home button flex.. more likely the dock.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you so much!! I just did what you told me and combined it with your water damage 3g iphone guide and now my Iphone is fully working!!
por
brilliant! glad to have helped and thanks for accepting the answer..it should help others in similar situations.
por
Adicionar a sua resposta
Jean Sebastien será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 2,187
