Ir para o conteúdo principal
Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
82 Perguntas Visualizar todos
How to install a system on an erased drive
My customer booted from an external drive and used Disk Utility to erase the drive. So the repair/restore partition is gone.
It boots and runs fine from an external drive but when I try to install a system it tells me it has to be connected to a power source but there is only the one USB c port.
Any ideas on how to get a system on it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
This is one of the big issues with the MacBook’s.
You’ll either need to get a USB-C hub so you gain access to a second USB-C port so both the power and your OS installer can be connected together. or use the WiFi connection to the Internet to do an internet recovery.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
mayer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 342
