will not power up
last night our lights kept flickering and now the wii will not power up.
Esta é uma boa pergunta?
When you say your lights kept flickering, do you mean the lights on your Wii, or the lights in your house? Either way, I would suggest trying a new outlet or a new power cable before opening the device up. Everything inside the Wii is located on the motherboard, and while repair is possible, it's relatively costly. Should a new outlet/cable not solve your issue, here are the guide and the part.
Esta resposta foi útil?
I had a problem with mine, we had a momentary power outage in the house and after the power came back on the Wii did not even light up. I unplugged the Wii and plugged it back it a different outlet. No help. Then I unplugged it and left it unplugged over night. The next morning when I plugged it in it worked fine. I spoke with some co-workers who also have Wii's and I have found that this can be pretty common. Anyway it's working fine now.
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 1,795
