Ir para o conteúdo principal
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Perguntas Visualizar todos
Kernal Panic when goes to sleep but never in safe mode
Kernal_panic_17APR
When the system comes up normally, if the settings allow it to go to sleep, I select the sleep option, or it attempts to turn the hard disk off, it reboots with a kernal panic. If I boot the system into safe mode, the touchbar is disabled and I can utilize sleep without issue. I believe changing the touchbar might fix the issue. Does anyone have thoughts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
While it’s not obvious you have two distinct computers in your system! Yes, the primary Intel CPU but you also have a second one which is the micro-controller that runs the Touch Bar.
Unless your Touch Bar is damaged somehow I don’t think changing it would fix this. There is a driver within MacOS that interconnects the two. From the sounds of it I would think thats your issue Vs a hardware issue.
If we could see the crash report then that might help. Open the Console app in the Utility folder in safe mode it will allow you to access the crash reports. You’ll need to paste it into Pages and then export a PDF file to post it here Adicionar imagens a uma pergunta já existente.
You could also just boot up under an external drive rename your system folder and then re-install your OS.
Follow this guide to create the needed boot drive How to create a bootable macOS Mojave installer drive
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you for the reply. I have added the pdf of the latest crash report. Also, I have attempted to reinstall the OS with no luck.
por
Did you re-name the current System folder? If not you need to do that.
por
Adicionar a sua resposta
Scott Caron será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 51
