Ir para o conteúdo principal
Console is not connecting to any wireless network
Okay so my console (which is an original xbox one system refuses to connect to any wireless network. Ive opened the console to ensure the wireless board isnt loose or anything, but its not. Controllers sync just fine (although they desync after the console is restarted) but my maun issue is wifi.
Here is a picture of the menu when I go to change networks (which none show up)
Any idea why its doing this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
I was able to fix it. I went out on a limb and tried replacing the Wifi cable. that seemed to have fixed it, so if anyone has this issue in the future, try replacing the cable. its a 15 minute repair.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
If you can 100% rule out an issue with the networks you are trying to use, it is likely a problem with the wireless card. I would suggest getting a new wifi board and switching it out.
Pontuação 1
2 comentários:
Thing is, I thought as much. So, I pulled the wireless module from a known working system, and had no prior luck. With that said, the socket the wireless board felt... Weird... There was little to no resistance when plugging it in. And when I hooked the wireless board from the system I am troubleshooting into the good system I pulled the board from, it worked just fine...
por
PCB issue maybe.
por
Adicionar a sua resposta
William Bosco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 143
