Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
How can I replace the case?
I got a xbox one s controller from my friend. I plugged it in and it works, however the shell is extremly damaged and just broken off on the back. On the frame, on of the triggers has broken off. So I basically have a working motherboard and that’s it. I was able to find a new shell, but anyone know where I can get a new frame? For cheap preferably?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Xbox One Controller (1708) Midframe Assembly
I found this item on IFitIt site. is this what you need?
Imagem de Replace a damaged or malfunctioning main circuit board assembly for a model 1708 Xbox One Controller. This assembly includes the plastic midframe and vibration motors.
Produto
$29.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jeremiah MayMayz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 117
