How do you remove and replace the keyboard on the GS43VR?
The original keyboard is held by plastic solder. Should i melt the plastic to be able to lift the keyboard?
Esta é uma boa pergunta?
Check out the tutorial and see if it works: http://www.laptopkey.com/Guides.php/MSI/...
Note that do not separate the sheets that are attached together in the keyboard. You can pull them apart where they aren't melted together, but if you break the bond(s) they will never align properly again.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 578
