Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
706 Perguntas Visualizar todos
Nintendo switch not charging after port replacement
I recently replaced my nintendo switch’s USB-C port and tried charging it and nothing just a black screen, then i got a nintendo switch battery which was fully charged and plugged it in and powered it on and still the black screen, any ideas as to what might be causing this? any help would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
It might be a motherboard problem
por
Adicionar um comentário
1 resposta
Solução escolhida
Most likely one of the chips on the motherboard is faulty. Could be the M92T36 chip and or the P13USB chip or possibly something else but those are the two most common. The easiest way to diagnose those is by looking for shorted capacitors near the chips like I show in this video: https://youtu.be/EP65185uGiA
Esta resposta foi útil?
Pontuação 3
5 comentários:
Hi TronicsFix,Thank you for replying, I believe i have faulty capacitors, Is there a specific capacitor i am supposed to purchase? Any help would be greatly appreciated!
por
@migjav It's highly unlikely that the capacitors are faulty. 99.9% of the time it's one or more of the IC's on the motherboard
por
Oh I see, but just in case could you provide me with the type of capacitors I am suppose to purchase if it does turn out to be a faulty capacitor. Thank you.
por
@migjav I don't know what they are. I've never had to replace one...even if I did I'd just take it from a junk board. Sorry
por
Hi seen your comments an IV got little bit different I replaced c port Nintendo switch lite it don't turn on I put charger in an turns on I can hear it working but have a black screen I'm just getting I to soldiering an not sure we're I went wrong thank u
por
Adicionar a sua resposta
Miguel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 39
Duração total: 2,953
