Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Perguntas Visualizar todos
Can I add another 8gb of ram?
hello, im new here so forgive me if this has been asked before a quick google search showed nothing so i came here. Can i add an extra 8 Gigabytes of ram (making it 16 gigs) to my 2017 macbook air 8 gigs isnt enough for me and i know it would probably be easier and cheaper to just buy a pro or something i just want to know if it could be ANY cheaper also would it be possible to add touch id i missed out i got it 3 months before the 2018 was relaeased because i was unfarmilliar with apples release schedule thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Sorry guy no options here! This series only offered 8 GB of RAM.
Esta resposta foi útil?
Pontuação 2
Go to https://uk.crucial.com/ or the American site I recon is https://crucial.com/ at the top click Upgrade my device and then scan my computer
Pontuação 0
5 comentários:
ok, i done that and it said they do not have any upgrades for me but can i upgrade too ddr4 ram? it says its non removable but techinically nothing new that apple makes is removable iphone xs max diy screen replacement? non removble bt it can still be done any ideas?
por
Everything is removable depending who is removing it. A micro soldering guy can do that. The issue is can the machine use the extra ram and how much are you prepared to spend doing it...
por
@drfixit_tech - Lets not try to be brain surgeons in the deep jungle! All the MacBook Air's have soldered RAM, only the SSD drive is socketed.
Don't forget the logic board is limited to 8 GB of RAM by the limited address lines going to the PCH.
por
Exactly my point, expertese micro soldering experience is needed to change the RAM
por
Thats not what you started with, besides what are you going to put in? The logic boards address lines are not present for the upper RAM So putting it in won't offer access to it!
por
Adicionar a sua resposta
Anonymous Guy In A Bush 33 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 105
