Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Overheating and drainage fast.
Hello,
i have a question.
I run an repair shop and i repaired like dozens of phones.
i recently refurbished my own iphone 8 plus device to make it look new.. but now my phone is overheating entirly but at the power button it is even warmer.
the phone also lose 1% every minute when using it.
-housing replaced
  • original battery
  • Oem screen
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I got the same problem :(
Have you fixed it?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Bad Tristar chip on the motherboard. Microsoldering required to repair it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Checked chip.
Its fine.
I notice when i am using the phone with on spotify and when using sound true top speaker the phone is getting hot.
Any solutions for that?
por
So,
This is the place where it heats up.
https://ibb.co/8Y5zDpG
On the front and at the power button it heats. The most i feels like 40c back site is little warm.
Rest of the phone is not as warm as the top
por
Did you try a new battery? Also go into your settings go to battery and than battery health. If its below 82%, I recommend a new battery anyways.
Pontuação 0
2 comentários:
Changed housing,
Changed battery
Changed screen.
Everything works normal...
Just special apps like spotify , gaming its getting hotter as usual... and then the battery drains way faster.. like half of the time as before
I am running ios 12.2. i refurbished this one and i put my back up on this phone and had to update it. So i dont know if it was befoee the update aswell.. thats the problem.
Is it possible that it could be?
-faulty screen
-proximity sensor?
- copy power flex
- copy dock connector
por
Maybe just backup your phone and then do a DFU restore to see if that fixes it.
por
Adicionar a sua resposta
glennjacobs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 756
