Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
678 Perguntas Visualizar todos
iPhone 8 plus no display or back light?
i have iphone 8 plus which is faulty and fault is no display or back light i have checked diode mode reading but nothing found, any one have solved this issue in iphone 8 plus ?
thanks
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Hi, I had a similar problem with my iPhone 8. What I did to fix it was, is I pressed the up volume, then the down volume, then hold power button till Apple logo comes on, or until 30 seconds is up. After 30 seconds you may have to find another solution or contact Apple: https://support.apple.com/. Hope this helps have a good day!
Esta resposta foi útil?
Pontuação 0
1 comentário:
Notthat helpful. This is a standard but poor repsonse to questions abut switching on.
This just switches the phone on which the original user said doesn't happen.
I have had the same problem for some time and am fed up with trivialised answers.
por
Adicionar a sua resposta
kgn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 990
