Ir para o conteúdo principal
The LG X Power is a 4G LTE smart phone that was released on August 2016. This model has a 16 GB memory with an Android operating system.
battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
Esta é uma boa pergunta?
Pontuação 12
13 comentários
My lg q6 alpha is showing the red question sign on the screen I don't what to do
por
What do I need too do if my phone want come on and only show a ? Mark
por
my lg is not turning on
por
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
por
I have the same problem in my lg v10 question mark after connecting the charger
por
Exibir mais 8 comentários
Adicionar um comentário
2 respostas
Solução escolhida
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
  1. Clean charge port. And cable connection
  2. Replace charger/cable
  3. Replace battery/charge port
Esta resposta foi útil?
Pontuação 6
5 comentários:
Hold finger on Questiomark for while..
por
still not working..... im getting mad
por
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
por
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
por
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
Pontuação 2
2 comentários:
If you get anew battery note to remove the stick on the 4 battery connectors
por
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
por
Adicionar a sua resposta
Jonathan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 166
Ao todo: 57,520
