Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
iPhone 7 Bluetooth not working
Ive been given an iPhone 7 to replace my old SE. Everything works as it should except for the bluetooth. When you go into settings, instead of the Bluetooth On/Off switch there’s just a spinning disc.
I’ve been through all the troubleshooters to the point of restoring it back to factory defaults with the latest IOS, but it still doesn’t work.
However I have noticed that when I put the serial number into Apples website, it should be a different color than it is (Apple say it is rose gold, but it’s actually silver) so I guess at some point it has been re-cased.
Everything else on the phone works fine including the 4G and wireless. Can anyone suggest what might be the issue with it?
Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
All that I know of that could help is to reset or hard reset. I don’t know what to tell you other wise, that really sucks. If it still doesn’t work try contacting Apple’s Support team: https://support.apple.com/contact. Hope this works.
Esta resposta foi útil?
Pontuação 0
If it has been swapped into a different shell then it could be missing and antenna, if you were to open it and take a picture I maybe able to help.
Pontuação 0
1 comentário:
I've added a picture of the inside, though I don't think it shows much...
Thanks.
por
Hello, I am having the same issue on an Iphone 7, anybody knows how to restore Bluetooth? (WiFi is ok)
Pontuação 0
Adicionar a sua resposta
Mike Wynne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 204
