Ir para o conteúdo principal
Fones de ouvido sem fio lançados em 2014 pela Sony.
Sony MDR1A doesnt work properly
ok so i couldnt find my actual device here but its sony mdr1a. when i first ordered it, it was working perfectly fine but then the left ear (where you connect the aux) started cutting out. I tried the other aux that came with the device and it worked perfectly; for about a week. I can’t connect to other Aux cables, because it has a very specific port (after the thin part, like the neck has to be slim to fit) and i havent found a single aux that goes all the way in & authentic sony ones cost 60$ on amazon! if you know what the problem easy please help and also theres no tutorials on how to disassemble it online so help would be appreciated! Also the left part makes squeaky sounds when you turn it around
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Did you end up making any headway with this? I have the same problem. The aux cable seems to be losing connection with the contacts in the port. Unfortunately it seems to be made in a way that cannot be disassembled without breaking it - there's a pin that holds in the port assembly.
Did anyone have any luck extracting this pin?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sandro Avalishvili será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 544
