Why is my ipad mini 4 rebooting at random
Screen goes blank then apple logo reboot
To no avail
done factory resets. Setup as new device.
Battery cycles around 400
device has latest updates as well as all app
Esta é uma boa pergunta?
To no avail
If you have a Mac or a friend with a Mac, download and run Coconut battery, plug your pad into the USB port and wake it up. Coconut Battery has an iOS option that will detail information about your battery
Esta resposta foi útil?
You’ve either got something shorting to ground in there, or you have a faulty thermal sensor that is causing the problem … but it is quite possibly something that is happening when the device heats up.
Try this … get a desk fan, and aim it at the ipad while you’re using it and see if the problem still happens or possibly stays running longer while its being cooled by the fan…
I think it's a bad battery.
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 525
