My display is slowly fading to white. Why?
The display on this mac will either fire up fine then slowly fade to white. Or if you move the display around it will distort (lines) and fade to white. I have over 50 machines that are this model and it has happened on quite a few of them. I am tired of sending them to the Mac stores and would like to repair this myself. I have done a bit of other research and some indicate that it could be the lcd flex cable ribbon. What are your thoughts? Have you seen this before? Do you sell this part?
Thank you in advance for your help!
Esta é uma boa pergunta?
4 comentários
Mine is getting white when brightness is more than 50% and when the laptop heats a little ?
In my country the replacement of LCD screen cost 160$
I just need to be sure that replacement will solve my issue
por yperano
Try turning off the "Automatically Adjust Brightness" under Displays in Systems Preferences. I have had this fix the problem in the past.
por Julie
Same is happening to me. I have just tried Julie's fix and hope it works. Though I don't believe that should be the fix. This computer is brand new. I will take back to Apple though. Because I'm still under warranty.
por Khaddy B
Same happened to me. I did as Julie stated and it solved the problem.
por Tonmoy Sharma
