Ir para o conteúdo principal
2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
85 Perguntas Visualizar todos
Mac Mini 2018 Kernel panic bug type 210
Hi,
I am getting random reboots and glitch screen, Sometime it’s don’t show for a day some time 2/3 times a day.
I’m using latest version of macos mojave 10.14.4
There is no hardware error with apple hardware check.
Anyone can help me?
Thanks
{"caused_by":"macos","macos_system_state":"running","bug_type":"210","os_version":"Bridge OS 3.3 (16P3133)","timestamp":"2019-03-05 19:25:49.76 +0000","incident_id":"EA706255-8D43-48A8-81C4-DF5240B37CC7"}
  "build" : "Bridge OS 3.3 (16P3133)",
  "product" : "iBridge2,5",
  "kernel" : "Darwin Kernel Version 18.2.0: Wed Jan  2 20:41:23 PST 2019; root:xnu-4903.241.1~3\/RELEASE_ARM64_T8010",
  "incident" : "EA706255-8D43-48A8-81C4-DF5240B37CC7",
  "crashReporterKey" : "c0dec0dec0dec0dec0dec0dec0dec0dec0de0001",
  "date" : "2019-03-05 19:25:49.72 +0000",
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Bridge OS 3.3 is the code that runs on the T2 micro processor. You’ll need to get your system to Apple to get the logic board replaced as Apple did have a bad run of T2 chips, you clearly got one of these. Sorry ;-{
Your system should still be under AppleCare warranty. I would strongly recommend you get the upgrade to AppleCare+ when you get your system serviced to be safe.
Esta resposta foi útil?
Pontuação 2
I was told by an Apple tech that their stores are CLOSED right now, as is much of California, while the “stay at home” policies are in place.
Pontuação 0
1 comentário:
Back in April 2019 the stores where open ;-} And I'm sure Shokat Jamil has a working system now.
Are you facing the same issue?
por
Adicionar a sua resposta
Shokat Jamil será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 3,281
