Ir para o conteúdo principal
The HP Envy 7640 is an all-in-one inkjet printer with a built-in scanner and faxing capabilities. It can be connected to your devices via Internet, WiFi, or a USB cable.
20 Perguntas Visualizar todos
Is it possible to improve, lubricate or replace the scaner roller
I’ve had the HP Envy 7640 all-in-one printer for a little over a year. I am wondering if there’s any way to lubricate, improve, repair or replace the roller located in the document feeder? I guess I’m asking if this is possible.. Much like you lubricate the roller-shredder on a paper shredder - using either the pre-lubricated paper sheets or the oil itself.. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If the paper is not being pulled into the scanner from the document feeder then it is probably dirty rollers. You can use rubbing alcohol on a lint free cloth to clean the rollers. You do not need to lubricate the rollers.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matthew Palmieri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 880
