Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
706 Perguntas Visualizar todos
How do you remove screws that are stuck but not stripped?
I’m trying to self-replace the joycon rail on the left joycon, and have run into a problem. The phillips-head screw on the rail is stuck on really hard, and will not spin no matter how hard I try pushing with my screwdriver. The screw is not stripped. How do I get the screw out without damaging the electronic parts?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Using a larger diameter bit holder-handle will give you more torque to help move it. Make sure the bit is the correct one that fits all the way into the screw head. There new several types of handles, some have holes in the handle (fourth down) that will allow you to insert another small driver to add torque (essentially turning the driver into a turnkey.
What are you currently using?
UPDATE
It’s really hard to do repair jobs with the proper tools. iFixit offers a couple of very good kits for the beginners and of course fine kits for the advanced. Here’s a couple you might consider:
[produto vinculado ausente ou desativado: IF145-435-2]
[produto vinculado ausente ou desativado: IF145-436-2]
Here are the other available kits:
https://www.ifixit.com/Store/Tools/Toolk...
Esta resposta foi útil?
Pontuação 2
2 comentários:
J00 screw bit appears to have the best fit for these screws. I ended up stripping the joycon screws due to using PH00 instead.
por
I'm currently using a tiny one used for eyeglasses and such. I don't know the model.
por
Adicionar a sua resposta
SawaYoshi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 35
Duração total: 7,646
