Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
What kind of switch is the on/off button
I have broken on/off switch what kind is it? SPST, Normally Open, or what? I see the two little wires that come from the back of the switch, Just wanted to replace it with common stock items.
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you, I thought it was a NO, but since it had broken off, It would come on as if power had been out and had then been restored.
por
Adicionar um comentário
1 resposta
Solução escolhida
It’s a simple push-button under spring pressure normally open.
If you can find the Bottom Housing Apple P/N 076-1210 it comes with the button.
Here’s one source Bottom Cover for Mac mini Early - Late 2006 & Mid 2007 It’s only $5.00 How can you go wrong!
If you live in the UK or EU Bottom Cover for Mac mini Early - Late 2006 & Mid 2007 It’s a bit more $25.00 ;-{ Maybe you can haggle a bit.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I have several SPST and a handful of NO's regular round red push button types, so I have one for free.
por
You need a momentary contact switch (push button with spring) not a SPST
por
Adicionar a sua resposta
Michael Inman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 379
