Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
Click sound on charging
Hello,
Someone gave me a Nintendo Switch to fix it.
What I’ve already done:
After unmounting it I found that the battery was dead (0V) so I ordered and mounted a new one.
But it was not working: battery at 2.8V so I suppose not enough to boot.
Then I tested the charger: 0V on the out of USB C on the Switch board!
So I borrowed one to test if it was really the charger or the connector.
The problem:
Now my problem is that when I plug in the cable I can hear a little regular clicking noise I think coming from the M92T36. It’s like a spark sound.
I don’t know if it’s normal, I dare not leave plugged in for fear of killing the battery / charger.
If someone can confirm me that I can leave the charger plugged in,
Thank you,
Emerick
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
From what I’ve heard is that if someone used a USB-C charger that wasn’t suited for the Switch would cause the charging IC to become damaged, more than likely that is the issue here.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hello @techmedicgr I don’t know if the person used a wrong charger but the one they gave me with the switch and the one I borrowed are both official Nintendo chargers.
I hope the charging IC is not dead because I have nothing to solder CMS…
I will try to charge with an external charger the battery and see if the console starts…
por
Adicionar a sua resposta
Emerick Herve será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 1,640
