Ir para o conteúdo principal
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Perguntas Visualizar todos
shows green light but cannot power on
Sorry guys for interrupting you but I kinda have a problem with my MacBook 820-2330-A.The machine shows green light but cannot power on,however when I press the power button and then plug the charger in the machine comes on but fans run at a very high speed and there is no backlight.I’m new to this stuff and I don’t know what to do…please someone help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
That points to an SMC circuitry failure as what you’re doing to start it is an SMC bypass. It’s a logic board issue that needs in depth probing and a component level repair, or a logic board replacement, which would be more suited from a DIY approach.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
KEN ROBERT será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 126
