Ir para o conteúdo principal
Pergunta encerrada
What is causing the bad picture on the internal display only
Xandu diagnosed the problem as a defective screen (not a defective Nvidia chip 86000 GT), so I replaced the screen and as this did not fix the problem I also replaced the display connector and the LED driver board without success it appeared at first. However, after starting up as single user the picture started to improve but also went bad again; low resolution, every other vertical line seems missing, low contrast. After repeating the single user startup several times it stays good for about a week now. What is happening? Were the replacements necessary?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This may be the Nvidia video chip problem. Hook up an external display and see if the problem persists. If the problem is still there you may be eligible for a free logic board replacement. Let us know your results.
Esta resposta foi útil?
Pontuação 0
1 comentário:
External display picture is fine, it seems to affect solely the internal LCD.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 694
