Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
Can an iPhone 7 plus be turned on without screen and digitizer flex?
Hello, I am from Venezuela so my english is not the best, I will try to explain myself.
Yesterday I tried to replace mi iPhone 7 Plus battery and when opening the iPhone I pulled the screen too hard and I broke the screen flex and digitizer flex
I realized that I have to buy new pieces, but I tried to make a test. I connected the iPhone to the computer to see if it gets recognized or not (with old and new battery) but it is not recognized by computer, my question is when I pulled it and broke the cables maybe I did damage another thing? or it is normal that the iPhone can’t turn on without the broken pieces
Hope you can help me, best regards.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
UPDATE.
So after finding another working screen and digitizer (but screen broken) for testing with my device, it happened that actually it TURNED ON, yes, it is alive. The guy who helped my out whit this situation told me that the iPhone would not turn on without the screen.
Hope this post can help somebody else. Thank you all for the answers.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi I’m going through this right now. I broke my cable when opening the phone. The vibrations not working, the phone isn’t showing any charging signs, and the phone wouldn’t connect to my pc. do I just have to change the display for it to work?
por
I just updated an iPhone 12 without a screen on it just to see what would happen because it was in an infinite bootloop. It actually updated!
por
Pergunta mais útil
I think it can but it will take a really long time for it to boot up like 5 minutes or more.
Pontuação 2
1 comentário:
Well no lucky for me, almost 5 hours connected to the Computer and no feedback from the device.
por
Yes it work without screen, just plug in your iphone to a computer and wait for few minutes to response.
Pontuação 2
2 comentários:
No lucky trying this :( maybe I did broke something else. no chirp after almost 5 hours conected to the Computer
por
Could you please add an image on what happen when the lcd broke so we can see any possible option.
por
Como estas, lo que debes es buscar una pantalla que este funcional y terminar tu reparación ya que si rompiste los cables que son (dos) debes de recordar que no hay comunicación del home buttom y el logic board.Como vas a tener que cambiar la pantalla tienes que tener muchooooo cuidad con el home button porque si lo rompes el flex tundras que llevarlo a Apple porque no servirá.
Buscate una pantalla y a reparar esa parte…si necesitas info de como quitar el home y la cámara con gusto te puedo ayudar..saludos!
Pontuação 0
2 comentários:
iRick28 - Publique en los carteles idioma nativo. Si están publicando en un idioma extranjero, publique en su idioma si puede, así como la traducción en inglés.
iRick28 - Please post in the posters native language. If they are posting in a foreign language then post in their language if you can, as well as the translation in english.
por
Gracias por tu respuesta, la cosa es que no deseo comprar la pantalla y todo lo que debo remplazar si he dañado por ejemplo la tarjeta logica, prefiero en este caso invertir en otro dispositivo, por eso deseo saber si aun faltando esas piezas el iPhone es capaz de encender
Thank you for your reply , the thing is that I dont want to buy a new screen and all the replacement parts if the device is completely damaged like for example the logic board, I prefer to save that money to invest in a new device, that is why I am asking if the iPhone can be recognized without the "screen parts".
por
Adicionar a sua resposta
NOI será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,042
