Ir para o conteúdo principal
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Perguntas Visualizar todos
Display lcd not working
The display does not light up but itunes detects the ipad. I disconnected the battery and it seemed to work, but after some use it is no longer accessible (itunes, however, detects it). Some advice? Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like maybe the LCD flex cable is coming loose. I’ve actually seen a guy smack the opposite side of an iPad 2 and correct a loose cable. Not sure if the 4 flex would react the same. It is a different connector altogether. You may try putting it on its right side vertically, then bump it down into your palm or lightly onto something kind of soft like rubber. Then soft reset. Hopefully your LCD isn’t going out and this helps. Otherwise you gotta open it up to investigate.
Esta resposta foi útil?
Pontuação 0
1 comentário:
It does not seem to be the flexible LCD cable. I opened it when I unplug and hang up the battery seems to turn on but only up to the apple. I do not know if the problem is the LCD or the battery.
por
Adicionar a sua resposta
Cristiano Zotti será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 37
