Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Reboot when i'm calling
When the dock connector is connected, it will restart.
I changed the dock connetor, but it not good.
What is the problem? :S
Esta é uma boa pergunta?
Pontuação 0
3 comentários
I may have a problem with the battery. (Really doubt that it’s the battery) it probably needs logicboard repair.
por
It sounds like you either need a replacement earpiece speaker or top components flex cable replaced. If the earpiece is not connected properly, any time it attempts to make sound through that speaker, it restarts the device. Should be as easy as top flex cable and earpiece replacement.
por
There have been a lot of problems with the dock connectors. Does it do that with a regular iPhone charger?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Front camera cable must have been ripped, this would be a fault caused by the proximity sensor somehow being damaged. See if it reboots with front camera disconnected.
Siri also uses proximity sensor so see if it reboots when you try to run Siri.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
ttdarabant será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 211
