Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
Water damaged iPhone SE logic board
(English is not my native language so I appolagize for some headaches that I might cause)
Hi everyone, I’m trying to fix my teacher’s iphone se that has been dropped in water and soap… I’ve already removed the logic board from it with the EMI Shields; and i’ve cleaned the logic board with 100% alchool.
With that I’ve found, with the help of a app called phone board, that the L3300; the T5301_RF and the L2000/2001/2002/2003 had sort of stains on them.
Is there any way to buy this components/ fix them?
Thanks in advance for helping me
ps: The phone is completely dead and neither the screen turns on nor it is recogneized on iTunes; I’ve noticed to that the battery doesn’t warm up even after 1 hour of charging
Images- L3300/T5301_RF: https://imgur.com/9IKsoWw
-L2000/1/2/3: https://imgur.com/LZSHbZk
Thanks again :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Liquid damaged phones are not that often repaired even by the best pros around, as they usually come with such a big number of faults that make the time and effort not economical compared to the price of a similar used phone ready available and with better reliability. Such repairs make sense mostly for data recovery or if the damage is very confined to a small area. If you have signs of liquid there in the middle of the board as indicated by the coils you listed I’d not recommend anyone to try a repair, unless you have weeks time to spend on a potentially hopeless project.
Esta resposta foi útil?
Pontuação 4
I would try denatured alcohol in a agitator. Forcibly get the corrosion off. One of the first things water does to a phone is zap the power. May look at replacing the battery, and possibly the screen
Pontuação 1
Adicionar a sua resposta
renatocapelo2003 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 223
