Ir para o conteúdo principal
Modelo A1311 / Final de 2011 / Processador Core i3 de 3,1 GHz / Modelo exclusivo para instituições de ensino
What cpu and graphics card are compatible with this iMac?
Hello, i have a emc2496edu imac and it has a dual core i3 with 256mb AMD Radeon HD 6750M is there a compatible graphics card and cpu for this upgrade? i would 4 cores and and at least a 1gb graphics card. and also is there a firmware patch i can use to get mac os mojave to run on it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
So what should i do at this point? Should i replace the logic board with a late 21.5inch 2012 imac logic board? Would that Even work? Or should I just sell my imac and put the money towards a new one?
Esta resposta foi útil?
Pontuação 1
1 comentário:
As I stated in your other question figure out how much you are willing to put into this system. I would focus on the CPU, RAM and If you can Storage (SSD). Also consider what you are planning on using your system for.
por Compartilhar
Hi Zachary,
The best option is to find some replacement parts pulled from old iMacs, though upgrading CPU to run Mojave, isn’t possible. Too many power draw issues.
Pontuação 0
1 comentário:
@iphonerepairman - Tim, There are solutions here without going that far.
por Compartilhar
Zachary - You should go back to your original question as the answer is there as far as upgrading your system. You can install either a i5 or i7 CPU. What cpu can I upgrade my iMac to?
As far as sliding in a 2012 logic board, sorry thats not possible! Apple altered the 21.5 system design quite radically in 2012.
An alternative to upgrading the CPU & GPU board is to replace the full logic board with the 2011 21.5” iMac with either a i5 or i7 logic board within this series iMac12,1
Pontuação 0
Adicionar a sua resposta
Zachary Schwanke será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 1,579
