Band Post on my VivoactiveHR cracked
The band post on my VivoactiveHR cracked and now the band is being held on by only three screws. Is there a way to repair that or get a replacement piece?
Esta é uma boa pergunta?
Here’s how to replace it:
Garmin Vivoactive HR Wrist Band Replacement
Band replacements are available on Amazon or eBay
Esta resposta foi útil?
It’s not the band that’s broken. It’s the plastic casing around the screw on the band post that secures the band to the watch. Thank you for trying though.
Leigh- This same thing just happened to my device. Were you able to find a solution besides superglue or duct tape?
Nope, seemed like a lost cause. I had luck for a bit with epoxy. Put some on and let it set. The craft epoxy that you have to mix might have been more permanent. I had a different watch I just ended up wearing though.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 774
