Ir para o conteúdo principal
Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
Whys does my screen keep turning off?
Hi, My screen keeps turning off while im using it. When I press the keypad it comes back on but then turns off a couple of seconds later. How do i fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Usually it is a virus that causes this problem. Seen it happen before on a Windows 8 laptop.
You’ll need to use anti-virus software like Malwarebytes Anti-Malware and Superantispyware to remove those viruses.
Does it only happen when touching the trackpad? See if it happens when touching the keyboard only.
Esta resposta foi útil?
Pontuação 2
Might sound a little stupid, but did you set your “turn off display” setting to Never in the Power Options section (specifically “Choose when to turn off the display” setting)?
Hope this helps.
Pontuação 0
1 comentário:
Could be a back-light needs changing ,depending on the devices age.
por
Adicionar a sua resposta
Jenny será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 3,259
