How to fix error C:13:01? re-insert memory card?
I have sony DSC-W380, then suddenly after using cannot open file. the image was C:13:01, re insert memory card. how to fix it?
Esta é uma boa pergunta?
I had this error about five years ago in a Cybershot camera. The error seemed to be caused by a bad contact between the camera and the memory stick.
I gave the camera's slot a blast of compressed air, cleaned the contacts of Camera & Memory Card and inserted &removed the memory card several times in quick succession.
And this solved the issue.
Esta resposta foi útil?
I already did but its the same, no changes. =(
If there is no important data on it, try to format it using PC/laptop
cannot also detect on PC/Laptop. yes it has important data.
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 71
Duração total: 3,039
I had the SAME PROBLEM! On the SAME CAMERA! I need to know this answer ASAP. I re inserted the memory card and that didn't work. I tried another card, that didn't work.
por Josh Patrick
