Screen will not respond after adhesive replacement
I replaced the adhesive on my Apple Watch screen and my touch screen stopped responding. I did several hard resets, which did not work. I removed the screen to check the connections, and the force sensor come off so I replaced the adhesive under the force sensor as well. Everything appears fine with the connections and the watch runs normally but the touch screen will not respond. I unpaired and erased the watch and that didn’t fix it either. I’ve replaced the adhesive in the past without unplugging the screen and taking it off the watch with no issues. This time I detached the display and digitizer cables per the instructions and now the screen Isn’t responding. Help!
Esta é uma boa pergunta?
