Ir para o conteúdo principal
An update released in May 2016 for Razer's 14-inch Blade gaming laptop. The first model in the series to feature a chroma backlit keyboard.
Is there a fix for fan speeed on this model?
Fans run on high from startup. The fix from razer doesn't cover this model. Is there a fix other than sending it in (out of warranty)?
Also, keyboard stopped working. I was able to fix it by reinstalling Windows, but that only worked 2 or 3 times. Now I have to use it in tablet mode.
Is it worth sending in for repair or just cut my losses and get something else?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
about the fan:
Download Fan Control
Download .XLM File
1. Install Notebook Fancontrol
2. Put the Razer Blade.xml file to --> Program Files (x86)\NoteBook FanControl\Configs
3. Start the Program
4. Choose the Pofile
5. Enjoy
If it won’t work, you can check your BIOS and customize them, but it’s on your own risk. The BIOS may include information about FAN and also can control FAN Options - For many times, it’s hidden under: "System Setup" or "Configuration" or some simillar name.
about the keyboad:
Check, if it’s really software problem - Check connection between keyboard and MB, also, check condition of wire.
If it’s really software issue, then:
  • Uninstall keyboard drivers
  • (optional) - uninstall Synapse drivers as well
  • Reboot your notebook
After the reboot, keyboard will boot up and start working as perfect, if not, try this options for a several times.
If nothing worked, there’s time for repair in service.
Esta resposta foi útil?
Pontuação 3
2 comentários:
thanks man my problem is solve cheers..
por
Is there a way to modify the fan curve on the xml file?
por
Adicionar a sua resposta
cmblanco813 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 31
Ao todo: 8,819
