I as well recently been having a very similar issue…
On initial start up of the PS4 I would get a system error indicating “Cannot Start PS4. Connect a controller and press the PS button”. I messed around in Safe Mode multiple times trying the different settings and even after a couple times choosing option #7 “System Initialization” the PS4 would then work properly for about a week before returning to this cycle of errors.
Finally I pulled the hard drive out and plugged it into my desktop PC and it did report some bad sectors, I wiped it and reformatted it (exFAT) and it reported “good” condition but still overall no luck.
Lastly I used a different hard drive entirely and this is where I am stuck. Upon booting into Safe Mode the only option I get is #7 which is a full system initialization. I have verified the correct file I put on the USB key which is the full system file and not just the update file (version 7.51). The PS4 reads the file, asks if I wish to continue because everything will be deleted and I proceed.
1) Step one, it does get to 100% full system initialization.
2) Then proceeds to do a system file update which succeeds (safe mode window)
3) then it displays PS4 graphics screen and does a second system file update and succeeds
4) then it reboots and does a system storage install which actually takes a bit of time to complete.
5) It’s then after it completes the system storage like building the database where it does a final reboot and then it displayed the PS logo but then just sits on a black/dark blue screen. The “blue” system light is continually pulsing if but will just sit there as long as you let it. I have pressed all the buttons and so on only thing left it to turn it off.
Upon turning it back on I get the “checking system storage”, it gets stuck at 24% and then other errors again about not able to start. If I go back into Safe Mode at this point I am back at square one with only option #7 as my choice as if it didn’t actually load anything we just saw as successful.
I will try a brand new store bought drive to eliminate the possibility of a bad drive but after this without dismantling the entire PS4 I have no idea how else to fix this PS4.
10 comentários
Is it properly ventilated?
por JAI GANESH NAIDU
I need help with my PS4
por Shane
I installed a brand new hard drive on my PS4 and initialized it. After it initialized it said it was going to download operating system when it restarted. But it keeps restarting in safe mode and will not load the operating system. I think I've tried everything I don't know what to do.
por Robert
And I used a full update file from PlayStation
por Robert
Also the power button is not working on the PlayStation 4 I started by turning on the TV and it turns on the PlayStation 4 but the power button does nothing.
por Robert
Exibir mais 5 comentários
