Ir para o conteúdo principal
The Ridgid 12 Volt drill/driver offers a compact, cordless unit capable of tackling projects within the office and household. This Hyper-Lithium powered drill bestows users with a longer lasting battery that doesn’t compromise on delivering strong torque output found across all Ridgid drill models.
5 Perguntas Visualizar todos
Drill is rotating the wrong way! HELP!
The drill is not rotating the correct way. All it is doing is unscrewing the screw.
Esta pergunta é pertinente?
Pontuação 3
1 dos comentários
student question
por
Adicionar um comentário
1 Resposta
Solução escolhida
Drills can slip off screw heads when the directional switch is not flicked in the correct spiral path for screws to move in and out of materials.
Esta resposta foi útil?
Pontuação 2
1 dos comentários:
this needs work!
por
Adicionar a sua resposta
Andrew McPherson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 378
