Unable to activate iPhone 6
Never came across this before. Iphone won’t connect to my WiFi but still picks up signal. Has been updated and restored but haven’t been successful.
Esta é uma boa pergunta?
What is the History? When was it activated last? Why was it restored initially? Are you sure you are getting Wifi but not connecting to Wifi? Looks like signal is from Data (Sim), maybe try activating with another sim? Usually have a searching or no service if data (Baseband issue)… Is IMEI Clean? need just a little more info on what started it all and some background… Bad NAND programming can also cause it
Esta resposta foi útil?
You can reset your phone witch may help.
iPhone 6 unable to activate try connecting your iPhone to iTunes to activate it, or try again in a couple of minutes
if this problem persists,contact apple support at apple.com/support
My I phone number 6 plus. But I have wrong right that can some want help me fit my wrong
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 1,659
3 comentários
No it doesn’t. It says about it can’t activate the phone and it may need a sim pin in order to activate.
por Ryan
will it activate using iTunes?
por chris
No it doesn’t. Says it could be a sim activation but nothing comes up asking about a sim pin so I don’t know if it’s that. I’ve restored the phone through iTunes but still comes up with this
por Ryan
