Ir para o conteúdo principal
Repair guides for the the LG V30, released in September of 2017.
20 Perguntas Visualizar todos
What glue to fix corners
I have broken my screen. All 4 corners are smashed. But no cracks run throws visible display. I want to glue corners to prevent falling pieces apart. Maybe some epoxy? Now it is only in surrounding part of screen. So something what helps keep it as long as passible without continuing falling apart. And then i would use a 3d protective screen glass. Which i hope helps screen also not to continuing screen decomposition.
What glue use for the corners?
Is my plan whit a protective glass use as plaster to add display bending duratibility totally nonsense?
I know i eventually will let change display in service shop. But for now i can live with this demage. So a cheaper temporary solution is what i want for now.
Thanks for any advice.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Try B7000 or E6000
https://www.walmart.com/ip/B7000-50ml-Mu...
E6000 Adhesive Glue
Imagem de A clear industrial strength adhesive. Bonds metal, wood, fabric, glass, ceramic, and other surfaces.
Produto
E6000 Adhesive Glue
$2.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Filip Raab será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 142
