Ir para o conteúdo principal
Portable Laptop Computer powered by an Intel Celeron Processor running on Windows XP. Model NO: MS2109
I want to make a server
I have 4 computer in the house and i want all of them to be connected to one pc as a server and control all of them with 1 computer…. what must i have and do?
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Hi @naunyango
What do you want to control and what do you want to do with?
File Server ?????
por
yes file server.
por
What is your OS? Windows 10? If so, it's easy.
por
Window 7 ,,,
por
Adicionar um comentário
2 respostas
I would set mine up as a Linux server using Samba because its free. Instructions here. You could also set up Apache and make your files available from anywhere.
Esta resposta foi útil?
Pontuação 0
Jonathan —
Choose the computer you wish to use as a “file server.” Then, select the drive that will hold the files you wish to access. “Share” that drive. Then, go to each of the other computers and “Map” that drive on each of them.
Instructions here: https://www.dummies.com/computers/operat...
I am doing this with a six computer network using Windows 10. Works great. Let me know if any questions.
Good luck,
Russ
Pontuação 0
1 comentário:
How to creat network password or which password do i need to use?
por
Adicionar a sua resposta
Jonathan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 297
