Ir para o conteúdo principal
A 3.6 V screwdriver powered by Black and Decker. Repair requires only common tools.
How do I remove/replace batteries in BLACK and DECKER
I own a BLACK and DECKER PLUG-IN RE-CHARGEABLE HAND HELD SCREWDRIVER
DP240 TYPE 2.
IT would not charge/ or hold a charge in the end. Found the replacement batteries at BATTERIES PLUS BULBS, the tech said the company would not allow them to un-solder
the batteries , so I purchased the strapped batteries and will install them myself but I need help in safely removing the old batteries and installing them without damaging the circuit board or its components.
WIllie E Brown
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello,
Follow these steps for replacing the Black and Decker.
  1. Firstly, Remove the screws.
  2. Remove the black sticker.
  3. Opening the plastic tool to pry cashing apart.
  4. Remove the plastic slider by picking it up off the screwdriver.
  5. Now, Remove the handle Screw and plastic tools.
  6. Using pliers or your fingers, remove the leads os the battery.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Mine has a wire clip that holds the gear head to the motor/battery body. Find the 2 tiny holes below the lock/unlock icons. Insert a tiny wire or awl to push out the clip.
por
Adicionar a sua resposta
WILLIE E BROWN será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 69
Ao todo: 2,915
