Front loading leaking while starting cycle.
Duo Sport. Leaked profoundly, clean water. I checked by pouring some water in the drum and running drain cycle. Works fine. As soon as I started normal cycle. I got water pouring at the front inside. took out the front panel w/doors and top panel. All the hoses look like new so is rubber around the door.
What else could be the reason for getting “niagara Falls” from the front left side. I even took out the bottom balance and the tub looks like new also.
I think I will run the cycle with everything open to see what is going on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
