Home button do not respond
Home button do not respond time by time.
And ear speaker so quiet. No any damages or
water spills. Thanks for help!
Esta é uma boa pergunta?
The home button not responding is probably the result of dust or a poor connection in the logic board. Here's a teardown to open it up and check out the connections. You can also blow some compressed air inside to clear out any dust.
As for the ear speaker, it's possible that there is a bad connection between the speaker and the logic board. More likely, however, is that the speaker is dying and needs to be replaced. Both can be done with the same teardown guide.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 756
1 comentário
any ideas guys?
por Vitali
