Ir para o conteúdo principal
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
SSD failed to restore
APFS failed to invert. OSS Error 22
Update (02/14/2019)
Mac mini (Late 2014) running Mojave (10.14.3).
I was able to clone the drive with the Carbon Copy Clone app. I'll know today if it was successful after I install it.
Thanks Jonah
Esta é uma boa pergunta?
Pontuação 0
1 comentário
What is the exact Mac system you are using as well as the drives specs.
por
Adicionar um comentário
2 respostas
Solução escolhida
Success! The SSD is up and running.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Disk Utility no longer works with APFS file systems for restoring/cloning devices. Using a Time Machine backup or Target Disk Mode on an old computer are the only ways to transfer data.
Pontuação 1
3 comentários:
Don't know why you're talking about Disk Utility here as we still have no idea what the system is. Until we get that you're just shooting in the dark.
FYI: The cloning options are no longer present in the latest version of Disk Utility
por
Are you restoring the drive with CCC or Disk Utility? I just want to double check where you’re actually seeing this error.
por
Error was with disk utility. CCC worked perfectly. Up and running!
por
Adicionar a sua resposta
Kenneth Hillman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 551
